greddy pan
blk90s13
for all u with the greddy oil pan did u use the other hole next to the drain plug for the pressure sender ??
i will be getting an oil pressure gauge and was wondering if i can use that hole there ?
I H8 UR DSM
its there for a oil temp gauge, not pressure
240_Keyy
Car: '90 240 Fastback
yes, the pan is not pressurized, so you can't put a pressure sensor in there...
blk90s13
ok any ideas where can i mount the pressure sender ??
slw240sx
Car: 1990 Ca18det 240sx Hatch
teed off the the pressure switch
