GReddy oilpan really necessary??
the_invisible
hi guys..
I have always wnted a GReddy oilpan because it is good looking and comes with new screws and such. It is also not very expensive.
But is it really necessary? My engine is from a clip and it won't have a dented oilpan. Also, it doesn't have any leaks, so I don't need to replace the gasket and thus, no excuse to upgrade.
Besides the fact that it stores more oil and allow the oil to stay in the center during cornering, is it really necessary?
Many high hp drift cars in Japan use the stock oil pan and has no problem, this lead me to believe that I shouldn't need one too since my car won't see any extreme acceleration and extremely hard cornering to actually cause oil starvation.
Is it worth it? It looks really cool....
Tai Mai Shu
Someone around here was drifting bottomed out, dented oil pan, oil starvation drifted again, and holes in the block. So its up to you but its a saftey issue. (saftey of your engine)
240_Keyy
Car: '90 240 Fastback
yes, well at least the stock oil pan can dent, the cast aluminum greddy pan can only chip and shatter...
I still have one though, and don't assume that just because your engine is from a clip that it will have a good pan. My engine was from a clip and my pan was dented as fook...
I H8 UR DSM
Dollar for dollar, its one ot the best modifications for your money
240_Keyy
I agree with Jesse on that one. I would rather not starve my motor of oil when autocrossing/road racing...
Drakon
Car: S13 hatch-SR+bpu's
how much is the greddy pan?
chrispy
Car: 1990 Nissan 240SX HB
Tai Mai Shu wrote:Someone around here was drifting bottomed out, dented oil pan, oil starvation drifted again, and holes in the block. So its up to you but its a saftey issue. (saftey of your engine)
thats was someone called djveletrik (sp?) on the FA forums.
themadscientist
if your oil pan is dented hammer the ***** out.
240_Keyy
agreed, but I wanted the greddy pan for it's extra capacity and flappers...
themadscientist
your reasons are valid and IMO it is well worth the price they want. More oil is a good thing.
240_Keyy
thanks, I try not to make frivilous purchases. They usually bite me right in the butthole...
nismofan14
Drakon wrote:how much is the greddy pan?
I think you can find it for about $200 - $250.
the_invisible
I am probably not going to have enough cash during my install to put on the oil pan. Do you guys think that if I want to replace the oil pan after the engine is in my car, the oil pan would come out without the need of removing a bunch of stuff???
Do you know what I mean?
nismofan14
I would definitely splurge a lil and put it on before the engine is in the car. It will save you alot of time and hassle that will come with changing it out later. I might be wrong and it isn't that bad to do it just seems to me that i would rather do it while the engine is out.
NEED4BOOST
Install the Greddy oilpan while you have the motor out. Piece of cake! Suck it up and buy one...like everyone said more oil is better!
I H8 UR DSM
the_invisible wrote:I am probably not going to have enough cash during my install to put on the oil pan. Do you guys think that if I want to replace the oil pan after the engine is in my car, the oil pan would come out without the need of removing a bunch of stuff???
all you'd have to change is the oil...and a gasket, or gasket sealant.
SRdave240
Yes, it would be simple - even if you do it after the engine is installed.
Nils
Car: road racing
no, you dont NEED the Greddy oilpan.
yes, it is VERY easy to install.
n
I H8 UR DSM
everything cool w/ the PS Pump nils?
Nils
Car: road racing
I H8 UR DSM wrote:everything cool w/ the PS Pump nils?
ya... everything worked out great!!
thx!!
n
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
GREDDY oilpan compatible with every generation SR? Enjuku advertises it for all 3 generations, but phase 2 only says s13. Or is it that there are different ones for each generation? I have an s14 SR and want a larger capacity Greddy oilpan. Does it really fit them all? Am I really screwed unless I pop for an ARC or something?
