n.r.wyatt »
https://forums.nicoclub.com/n-r-wyatt-u77044.html
Sun Nov 18, 2007 3:22 pm
I decided to do my 3000 mile oil change today. As this being a routine procedure for me i do it pretty mindlessly. So i jack the car up get under and pull the plug. But stupidly i take out the wrong one... The greddy pan has 2 plugs one right next to the other. The one on the left is the normal drain plug... i took off the one on the right. I some how backed this thing all the way out. The nut on the inside is still on the bolt. There are 2 small studs on the nut that fit into a washer above and below the hole on the inside of the oil pan. I attempted to insert this two studs back into the washers but with no luck. So my question is.. what is the best way putting this back in? Must i take the entire oil pan off? and has anyone else made this same mistake and can maybe guide me with what they have done.
I did spend about the last 2-3 hours searching for an answer. If i somehow missed a post like this i appologize.
Thanks,Nick
