Greddy Oil Filter Block Adapter
SloS13
http://www.greddy.com/products...e.htm (bottom of page)
ANybody running one of these?
Id like to have my oil gauge, oil feed and oil pressure all working and this seems like it'd make it a lot easier, and they're easy to find for around $55.00. Just wanted to know if anybody had experience with one of these.
silviaNE
Car: cars what else?
Yah, i have used it. Works good, but for 10 bucks you can make an adapter from the oil pressure dummy switch. The adapter is nice quality. I would like it more if you had the ability to run an oil cooler with it also.
SloS13
You mean you can't run an oil cooler with it? Whats that big plug in the picture for? Is it for filter relocation?
I guess you could run a cooler with one of those, but you;d have to do the relocation also
Xero
not to bring this back from the dead, but usually in order to run a oil cooler, you run relocation too, that's how NISMO's is set-up, GReddy's seems to be set-up that way too, and I believe HKS's is set-up that was also,
edit: actually, now that I look more into it, it appears that the adapter block would be for if you didn't want to relocate, so you can't use a cooler. but their relocation kit will allow for everything you want, but is a bit more expensive, and it doesn't come with a cooler core, but those are cheap from Jegs,
