Greddy Oil Adapter Thermostat
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
Just purchased this from 240xmotoring and awaiting its arrival. I also purchased an adapter to use my oil pressure gauge in this, but dont know which port to mount it in? I plan on using the top two ports for my oil cooler..so which bottom one do i use for the oil pressure sensor??
http://www.240sxmotoring.com/groilcoadw.html
^^tis the link.
themadscientist
I can't see the sensor bungs. Most sandwich adapters have two holes with different sizes. Either will work, just use the one your sensor will thread into.
sjbsuperman1425
CA18DET
i dont believe this does though, as I bought a -10AN to 1/8npt adapter from them also.
themadscientist
I have seen some that have a big hole with a plug threaded in that has a smaller hole. You should be fine. Senders only come in a few common sizes.
sjbsuperman1425
CA18DET
i know it'll work, im just curious as to which hole to install the pressure sensor into since there is a thermostat in the adapter..
themadscientist
I would put it on the return side. It looks like both sides see pressure but if one would read lower, I would expect the side on the cooler return to be it.
sjbsuperman1425
CA18DET
in piciture above:
Top Right - Cooler FeedTop Left - Cooler ReturnBottom Right - Blocked OffBottom Left - Oil Pressure Sensor
thanks TMS.
themadscientist
Oh, I see. I would put it on the feed side.
You kids get the cool stuff. Back in the day we had to stack two purpose-built sandwich adapters. We didn't have one that did it all.
sjbsuperman1425
CA18DET
lol bottom right in pic it is. i thought maybe the thermostat being closed would obstruct the flow to the sensor or something so i wasn't sure. I'll get ahold of the boys at 240sxmotoring just to be sure and what not. Thanks again TMS
themadscientist
Now I'm off to go make BH cry some more!
tEknoS13
Car: 93' Type X
^ You have become my favorite mod lol
Chris28
Car: 92 s13 KA-T
TMS you can stack adapters? I thought about it the other day but it was a totally random thought haha. I have no need to and don't think I ever will, I just thought about having like 5 sandwiches in there.
OP you've got a pretty nice sandwich for your feed line. I'm hungry...LOL GET IT?
themadscientist
Of course. A good adapter should allow you to use your normal filter so just screw one adapter to the other than the filter.
sjbsuperman1425
CA18DET
lol thanks. i spent the big bucks ($120) on this thing and the gauge sensor adapter thing so it better work! now im just waiting for Monday to come so i can confirm where to put the oil pressure sensor on the sandwich so i get the best reading, otherwise the sandwich i have on my car now will stay there and i'll use that!!
sjbsuperman1425
CA18DET
let me ask this, is anybody using this? lol
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
I was thinking of getting something like this. But I don't know. I'm looking for a block/sandwich plate that has a built in thermo and that can run a remote filter and hook up two gauges via 1/8 NPT ports. Am I asking for too much?
Also is there some sort of "splitter" that allows you to use two sensors on one port?
brizanden
Car: thrased kouki ftw
post pictures of how you did everything imma be gettin this.
sjbsuperman1425
CA18DET
there are 4 10AN ports on this. I purchased a Greddy adapter to 1/8npt from 240sx motoring when i bought this for my oil pressure gauge, and am mounting my oil temp gauge in the pan, but you could just buy another adapter and mount the temp sensor there if you wished.
I wont be installed for awhile, but i'll be sure to post back.
sjbsuperman1425
CA18DET
im resurrecting this just to be sure of which ports to use as the feed and return.. in my post above with the picture, would that work?
PhopsonNY
Car: 1989 Nissan 240SX
sjbsuperman1425
CA18DET
you wouldn't believe how fast i learned Japanese, or was it how to differentiate colors? hmm, either way thanks lol
kouki munster
Car: 97 base 240
sigh........
sjbsuperman1425
CA18DET
kouki munster fails, sadly. Not only did someone post a link that answered my question, but the one you posted isn't even the same adapter as the picture i posted above. Sorry..
kouki munster
Car: 97 base 240
Not really, if you use your brain and go to frsports web sight you could compair pictures of the one I posted and the one you have, then figure it out on your own instead of having someone spoon feed you the info.
And excuse me for not reading the whole thread and clicking on every link before posting.
sjbsuperman1425
CA18DET
sorry i didn't COMPARE the pictures since they are completely different pieces in orientation, design, and use. But yea thanks, i have my answer.
tctomasc
Car: 95 240sx
lol, thats not even close to being the same thing. I have this adapter on my KA. Car doesn't run yet, so I have no input as to how well it works, but at least on my car, i didn't need to use the extra ports. I took out the idiot switch pressure sensor, and put my own sensor for a gauge in there, and there was a plug on the oil stand right below it that i took out and threaded my oil line for the turbo into.
To answer maj's question, most sensors youse 1/8" Male Pipe Thread, so you can go to a hardware store and find a female 1/8npt T and a male to male 1/8npt and you will have 2 ports instead of 1.
killernoodle
Car: My daily: 2005 Cadillac CTS-V - pretty much stock
Brother's S13 project car: SR20det, wilwoods, suspension, q45 diff/axles, 315s out back
Thats an expensive sandwich plate!
