S13FASTBACKSR »
https://forums.nicoclub.com/s13fastbacksr-u34823.html
Sun May 07, 2006 2:20 pm
I just upgraded my turbo to a t28. I put it on a ssa mani and bought a greddy 02 dump to go with it. The problem is once i hooked up everything up i tried dropping it all in and the o2 dump wasnt clearing the steering column quite enough. The mani sits on some of the studs (the studs toward the back of the engine) a little more than the others (the ones towards the front, where they barely are sitting on at all) and the manifold also sits at a downward angle. I need to push the manifold up and onto the studs but i cant because of the clearence issues with the o2 dump and steering column. Has this happened to any of you before with this o2 dump. any suggestions? I'd prefer not to bang in the o2 dump with a ballpeen hammer either because the exhaust flow is divorced from the wastegate flow and I dont want to block off the flow from the wastegate, but if thats what I've got to do then I guess I will. Thanks for the help
