240life »
https://forums.nicoclub.com/240life-u76914.html
Sun Oct 25, 2009 1:49 am
Your HKS hot pipe should work...for a fmic prep you are going to need to get a skinnier battery (forget the brand) or a battery relocation setup. The battery tray will need to be removed also where the tray was will need a hole cut from it, along with the other side, and your bumper will have to be removed .......... (trimming of the bumper if it is OEM will be required too for intercooler clearance) its alot of work but its all pretty simple
