I've been wondering if the new Greddy turbo kit would work on an S13. I realize the e-Manage would have to be reprogrammed since it's pre-programmed for OBDII. But other than that...
Is there any difference in engine compartment layout between an S13 and S14 ? (any reason to suspect plumbing problems)
Is there any difference in exhaust manifolds ? (or other reason to suspect the manifold won't line up)
Difference in injector placement in intake manifold ? (or other reason the fuel rail wouldn't line up or injectors won't work)
Any input would be appreciated. Thanks.
