Greddy intake manifold
S13Sil-line
Car: Full throttle-*** out sideways
If I were to buy a Greddy intake manifold for my RB25DET, what else would I need to make it work properly. Not things to make performance better, but just to make it work. Thanks.
jdmser
Car: duh
Hey, I email you a while ago and didnt hear back. Do you still have the lsd in your sig? And I think you need intercooler piping to make the Greddy work, but that just from looking at pictures.
eh?
The adapter for the stock TB if you were yo use it. Cold piping with a fitting for the iacv hose. Fitting for relocated stock bov or other. IM gasket.That's what I could remember.
S13Sil-line
What about the Throttle body, and aside from the intercooler piping anything major? And yes I still have the LSD. I had some major e-mail problems. Mail again please.
eh?
the Greddy IM is made to work with the Q45 TB, Greddy sells the adapter to allow the stock to work.Aside from piping it's simple, just cutting some hoses.
Bluefire
either get the greddy tb adapter or q45 throttlebody, custom ic piping which means your probly gonna want to get a front mount at the same time. Your also gonna need some hosing to recirculate the from the stock bov... and thats all i can think of right now
-Bluefire
S13Sil-line
I have a front mount, thanks. How much and where can I get a Q45 TB. Also what about the throttle cable? Do I have to mod????
eh?
http://www.car-parts.com
Throttle cable I don't believe so, (my s14 cable works) You will need an unmodified TB cable bracket.
frosted flakes
would the rb25det greddy manifold work for the rb20det?
eh?
no
SillyRB
U need a Q45 throttle body to full utelize the Greddy intake manifold...However u lose power w the Trust intake manifold on the stock turbo..
silline
Car: drift n
yes you do need to modifiy for the throttle cable plat greddy has the adapter plate where do you plan on getting yours i need one asap if you have info on one thats in country pleases hook me up
Sil240
Car: Nissan S13 "The One Cam Wonder"
Are you sure the Greddy ITM wont fit on the RB20???Cause i want a manifold cause my IC piping is gonna be retarded
S13Sil-line
I know it won't fit the RB20.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
Sil240 wrote:Are you sure the Greddy ITM wont fit on the RB20???Cause i want a manifold cause my IC piping is gonna be retarded
you should check out the Hybrid Intercooler and piping kithttp://www.240supply.com
I just installed it on my 25, but the owners son has the same kit on his 20.
krayton
is the manifold made for side feeds or top feeds?
or both? im assuming the stock side, but id just like to make sure.
thanks
Bluefire
The Manifold allows you to use either the stock rail and side feeds or the greddy fuel rail with top feeds
-BLuefire
aimcheater
Car: 240sx
nismo_rb25...
is this IC and piping kit bolt-on? that would be excellent
