greddy intake manifold problems
Legoinry
Car: 240 SX se
hi im in the ending phase of a rather large build i have replace the stock s13 manifold with a greddy style one im have some problems with a few things the first pic im trying to figure out where to run it to and what is for looks like coolant second pic is of a nipple on the valve cover wondering where to run it to now and the third pic try not to laugh to hard i cant remeber which is oil and which is coolant lolhttp://viewmorepics.myspace.co...32580 http://viewmorepics.myspace.co...32582 http://viewmorepics.myspace.co...32585 http://viewmorepics.myspace.co...32587sorry about the links i counldnt figure out how to post the pics to the site
Modified by Legoinry at 9:53 AM 7/4/2009
virus77
Car: 95 S14, 71 240z, 97 e320
The big one under the intake manifold is the idle air control valve, you need to connect it to your intercooler pipe right before the throttle body.
The one on the valve cover is the PCV, you can simply plumb that into one of the intake manifold fittings.
the fittings on the block will make sense when you put the turbo there, its only gonna reach one place but I believe top is oil and bottom is coolant.
