S14-NEO »
https://forums.nicoclub.com/s14-neo-u25945.html
Thu Feb 05, 2009 2:14 am
nah everything lines up just same as far as the head ports and studs go.. the only issue you will have is the fuel rail, stock throttle body will not work at all, (keep in mind when you omit stock throttle body you will have a CEL cause the traction control will be offline).and the last thing will be you IAC valve. the stock IAC valve doesnt line up at all. you can use a block off plate or you can can get ahold of a 1.6L sentra IAC valve from a 91-94 i believe.its the same identical part.
