Greddy intake manifold /install??
2.240s
Car: 240
redtop s15 turbo, fmic,boost control,intake,3in. exhaust,dual fans/koyo radiator.stock mafs,any tips on install, is this a real pain in the a$$. once installed will the stock ecu execpt it?will i notice the upgrade?
hayaimoto
Car: Sil80,full race EG6,Street DC2, Real deal RHD FEEDfd3s
Well Im sure that you wont have to upgrade your tune your ecu, but there should be a little bit more power increase....depending on how much you plan to boost, your should only see significant increases during higher boost (16psi+). Thats from my experience. Hope that helps
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
On the Red Top S13 motors the GReddy manifold is the collector and runners so it is a bit or work. You will need to transfer injectors, all cables, sensors, etc etc so it wil theke the better part of the after noon. If you do it go ahead and get a set of o-rings for the injectors and all gaskets (don't be a silicone junkie). You'll only notice the diff above 4500rpm but it is about 20hp at 5000rpm and 33hp at 7500rpm from when we did a dyno on an S14 GReddy Intake Manifold. Note that this was on a S15 turbo set at 15lbs boost. For the money to hp value it is very good. Keep the inside of the motor clean also or your going to have issues.
2.240s
Car: 240
doridori23 wrote:On the Red Top S13 motors the GReddy manifold is the collector and runners so it is a bit or work. You will need to transfer injectors, all cables, sensors, etc etc so it wil theke the better part of the after noon. If you do it go ahead and get a set of o-rings for the injectors and all gaskets (don't be a silicone junkie). You'll only notice the diff above 4500rpm but it is about 20hp at 5000rpm and 33hp at 7500rpm from when we did a dyno on an S14 GReddy Intake Manifold. Note that this was on a S15 turbo set at 15lbs boost. For the money to hp value it is very good. Keep the inside of the motor clean also or your going to have issues.
Right , Thanks for the info. I might as well go with z32 maf and 555 injectors with a rom tune while i am at it.
Emperor_Tha
not trying to thread jack, but what about a stock black s13. would u have to get it tune for the manifold?
doridori23
Emperor_Tha wrote:not trying to thread jack, but what about a stock black s13. would u have to get it tune for the manifold?
nope but it will take 3-5 days to see full hp gains as the ecm will actually adjust fuel settings after a few drive cycles.
doridori23
2.240s wrote:Right , Thanks for the info. I might as well go with z32 maf and 555 injectors with a rom tune while i am at it.
Do you have a fuel computer? If not I would go with a GReddy Emanage Ultimate, map sensor (GReddy) and iat sensor (AEM). You will lose the maf altogether with the setup and if you have to spend $150 on maf and $300 on a fuel computer you have almost payed for an emanage. The Emanage Ultimate is my highest recommendation for ECM tuning. Why pay 500 for a Rom tun that is a one shot deal, upgrade and you need another rom tune, say goodbye to a grand. The Emanage Ult is super easy to setup and you can even set a target afr and it will do the basic fuel tune for you. If more people would install one it would mean less posts here for troubles and more burnout/drift posts! btw you still retain OBD2 functionality and has an internal troubleshooter for motor problems
2.240s
Car: 240
Words of Wisdom,I agree , you can also adjust for altitude change's over here in cali, Thanks agian for the info.
LessRice
Car: 97 240sx, 00 Civic Hatch, 03 350Z
