S12_hybrid »
https://forums.nicoclub.com/s12-hybrid-u41151.html
Mon Aug 21, 2006 1:47 am
Well truly it isnt a greddy, but it was cast from the same mold (even a square where the greddy badge should be).
Downsides of this manifold? It came with no installation instructions, or fittings. I have figured out the most obvious ones, like which vaccuum lines will be going where (built in vaccuum plenum), and the coolant bridge (below fuel rail/runners), throttle bracket, also the AIC has been connected.
I stupidly allowed someone else to do most of the bolting on, and therefore was left with many a hose/line/connection unlabelled and just kind of hanging off the motor. I know some of these are redundant coolant and vaccuum lines (for the TB). There is a threaded aperture near the back of the plenum on the bottom side, which has no hose to it, what is it for?
I can get pictures up tonight, but if any of you guys have a greddy intake and the install sheet, it would be a lifesaver if you could scan and post it.
Thanks!
