greddy emange - pinout help
boost infested
Car: cars, chicks, food, and .....
stock 93 ka24de ecu pinout # for:
MAF = 16?Tach = 3?Ignition = ?o2 = #19(correct?)
inj 1 = #101inj 2 = #103inj 3 = #110inj 4 = #112
thanks.
huguetpj
Car: 93 KAT Coupe
If no one responds I'll get back to ya when I get home tonight. My FSM is in my room :pface
fiznat
Car: Grown up :(
Heres the pinout for a 95 ECU, although I guess it's a little different.
http://www.240sx.org/faq/artic...t.htm
Hangon while I find the S13 one.
fiznat
Car: Grown up :(
aha!
I knew I'd seen it someplace! Credit goes to the yahoo e-manage group. DEFINETLY check them out for answers to most of your e-manage related questions.
boost infested
above diagram is wrong!
from the diagram #16 is Ignition but its not! #16 is MAF.
#1 is not Ignition because my car wont fire up with #1 to Ign IN/OUT.
the car is running fine now with all injectors, power/ground, tach, and MAF. so i need to know where connect Ign IN/OUT to!
fiznat
Car: Grown up :(
hold, Ill check the FSM
fiznat
Car: Grown up :(
ok
this wiring diagram is really hard to read, I dont know why they did it this way, but:
#16 is definetly MAFS ("air flow meter" on the diagram)#19 injector 1#18 injector 2#14 injector 3#12 injector 4
now, as far as ignition, pin #1 connects to the "engine room harness" at "M53" (presumably a big connector there), which in turn connects to the "Ignition Switch ACC or ON" Looks to me like #1 is the right pin.
Maybe something else is wrong?
EDIT:I could be reading this diagram wrong. Actually I very well might be... Its weird, if you try to trace the line back you get to a specific pin, but there are numerous lines leading from one system to the ECU (for example, the MAFS has pins 16, 17, and 38/47. I need some sort of way to read this easier :(
boost infested
17 and the rest are ground.
huguetpj
Car: 93 KAT Coupe
boost infested wrote:stock 93 ka24de ecu pinout # for:
thanks.
According to the 93 FSM:
MAF = 16Tach = 2IG = 47 or 38 (prefer 47)O2 = 19inj1 = 101inj2= 110inj3= 103inj4= 112
boost infested
thanks sir.
fiznat
Car: Grown up :(
huguetpj, whered you find that in the book? just tracing back those lines on that huge wiring diagram?
huguetpj
Car: 93 KAT Coupe
fiznat wrote:huguetpj, whered you find that in the book? just tracing back those lines on that huge wiring diagram?
Yep. The hardest was the MAF signal cause it has 3 cables coming from it. I just decide on the wire which the SAFC wiring schematic instructs to use (#16).
