jerryd1987 »
https://forums.nicoclub.com/jerryd1987-u188669.html
Fri Jun 27, 2014 1:32 am
dont waste your time with the emanage, its one of the worst ecu's you can buy for the car and why it costs so little. its the cause of many blown engines because it isnt even remotely accurate and offers no safety features, putting in 20 degrees timing could get you anywhere from 18-22 degrees. it has no nitrous control because it has no input that can trigger a timing retard the extra harness simply allows you to tune spark timing, which is the only way you will gain power through tuning it without other mods. simply adjusting fuel dosnt add power, more then likely it will kill power. literally save up for uprev if you want to tune but unless you have some sort of FI your wasting your time, if you have a couple bolt ons just get a flash. the first thing every person does with the emanage when they get the twin turbo kits it comes with is throw it in the trash. if you REALLY search on the ecu for the z/g you will see a legacy of carnage in blown engines.
