fiznat wrote:c-kwik, thanks for the info
hm, that's alot to think about. lemmie try to break it up.
1. the idea of tuning only at WOT to keep the ECU in open loop mode: isnt this going to really limit our ability to tune this setup? I mean, I suppose we could hit most cells by simply opening up the throttle starting at each RPM (or by 500 rpm increments or whatever), but there are bound to be points we miss... although I suppose at that point you can always fill in the holes with averaged numbers... still, it seems less than ideal.
2. grounding out the injector to provide extra pulsewidth seems like it might be a valid technique, but what about times when you want to reduce the amount of fuel sprayed? I dont know if this ever comes up, but how does the e-manage deal with this situation? ...reducing the MAF voltage?
3. Not sure whatcha mean about the timing. I admit this is my first real experience with this kinda stuff, so bear with me.. whats the difference between "tuning the acutal timing" and "changing the base timing?
1. You can tune at part throttle, but my point was actually that the ECU will want to adjust it according to the O2 sensor feedback. This will be most detrimental in high boost applications where part throttle can still boost fairly high and the feedback may cause a condition that might be somewhat leaner than safe or optimal. But this is where the additional injection map might be able to help. I'm not sure the ECU can fight this since the E-Manage provides the ground to hold the injector open longer. As far as between increments, the E-Manage autmotically calculates the tuning between one increment to the next in a straight line between them. So if you were to plot each point on a graph, then connect each point with a line(connect the dots) you'll end up with your tuning map. And with the E-Manage, you can set your increments manually. So you can actually use a higher resolution mapping at higher RPMs and use a lower resolution at lower RPMs. In other words, you can space tuning increments at every 1000 RPM's up to 3000 RPM, and then maybe every 250 RPM beyond that. Just as an example.
2. To lean it out, you would have to adjust the airflow signal to make the ECU think it's not getting as much air. But as with above, the O2 feedback may cause it to run the ECU's A/F ratio at the given inputs. But I'd be more concerned with running to lean than too rich.
3. Tuning the actual timing would mean that if you set the timing at 20 degrees at WOT at 5000 RPM, then it would be at 20 degrees. Tuning against the base map means that if the ECU puts the motor at 20 degrees at WOT at 5000 RPM and you input 5 degrees into the tuning map, it increases it to a total of 25 degrees.
