skillzilla »
https://forums.nicoclub.com/skillzilla-u17041.html
Mon Sep 13, 2004 3:07 am
Im running the E-01/E-Manage on an RB20 and it works great. I havent done tuning on the fuel maps yet, but you can adjust them from the LCD screenwith 16x16 maps and zoom to make it easier on the eyes.
One piece of advice though, get the external signal harness and the ingnition harness (about 60 bux total). The signal harness is to get a throttle position for the air flow map and the ingnition harness can do + or - 20 degrees of timing, plus MAY be able to run as an injector harness too (havent tried yet, Ill tell you next week ). The injector harness can control duty cycle and upgraded injectors, as well as additional injectors if you need/have em.
So far, with only using the EBC features, its an awesome set up. You can set hi/lo boost for three different maps stored on the supplied SD card, and set gain (to keep the curve level) and start boost (to spool quicker) for each one. Auto mode works fine, or you can use RPM points to make your own boost curve.
The SD card also holds three different E-Manage set-ups, so you can have fuel/ignition/injector maps for, say, street/drag/race, and keep them saved until you need them, then its only a matter of loading them and sending the info to the E-manage (about two minutes).
All in all, its a steal
Pics of my set up, in the glove box (pics were taken from the drivers seat):
