tollboothwilley wrote:The Emanage Ultimate will give you a few more functions over the Emanage blue. Emanage blue can be upgraded to the Ultimate with just a few additional wires.
The Emanage Blue and Ultimate have fundamental differences. The biggest being that the Ultimate can drive the injectors 100% independently of the ECU. The Blue controls the injectors simply by altering the mass airflow signal. It can however add more injector pulsewidth by providing its own ground. But it can't shorten the pusewidth other than by telling the ECU that less air is entering the engine than it is actually getting.
The Emanage Ultimate can be rigged to completely bypass the ECU's injector signals. By providing its own injector drivers, it can independently alter fuel curves without altering the MAF signal. So the ECU's ignition and VTC maps remain unaltered. The tendency for any ECU map is that under low airflow conditions with high throttle (relative to RPM), timing gets advanced. So any system that uses the MAF to trim fuel could end up with more timing advance than is ideal. Especially in situations where larger injectors are used. The Ultimate eliminates this issue altogether.
Unless there have been some major changes in the Emanage Blue since I had one, you can not upgrade to the Ultimate other than to buy an Ultimate. If that were the case though, why would they still offer 2 different products?
tollboothwilley wrote:You can pick up a emanage blue/ultimate fairly cheap. For FI, you might consider going against the Emanage though, as it is a piggyback and you can't adjust the open loop, only closed loop.
The Blue does fight the ECU in closed loop operation. In open loop, it will go by its own maps relative to the airflow the Emanage Blue tells the ECU its receiving.
This is the part of the Ultimate that I don't know for certain about. If the Ultimate accepts the signal from the O2 sensor, then I would imagine, it can be programmed for open or closed loop operation. Otherwise, since it is independent of the ECU, it would essentially run open loop all the time. In such a case, I would imagine a MIL light may come on if you get the A/F ratios too far off from the factory target.
Either way, the fundamental differences make the products very different in how you can use them. The Ultimate being much more flexible.
