darkforcejackal »
https://forums.nicoclub.com/darkforcejackal-u12107.html
Sun Oct 08, 2006 11:14 pm
I wrote the above linked article...i'll give you the short version...
Since you are recirculating, you'll need to:
-- Order the Greddy-RS 34mm adaptor (the blue mouthpiece that screws in - the 19mm adaptor is too small), about $20, and use much larger tubing/plumbing to recirc the air back to your intake piping (also with a larger nipple)-- Remove the smaller spring from inside the BOV-- Loosen the allen-key adjustment bolt all the way out, and then maybe half a turn or so tighter
With mine set up like this, it will never surge and actually "blows off" at less than 1 PSI....
Video is coming as soon as I can upload it...sounds interesting recirc'd actually!
Good luck.
