greddy/ aftermarket oil pans
goldollar
Car: cars
ive been looking up aftermarket oilpans, and i know the greedy comes with a port for oil temp but does it or any other pans come with a port for oil pressure.
240_Keyy
Car: '90 240 Fastback
only two ports on the greddy pan are the drain plug and the one for the temp sender.
goldollar
Car: cars
could you use the port already there for pressure, and if not could you drill a 3rd port
Honda Hick
I may be wrong, but I don't think the oil pan is pressurized. You have to tap into somewhere after the oil pump like by the oil filter or stock oil pressure sensor.
goldollar
Car: cars
dough that does make sense never mind then, im just a dumb *** newbie
240_Keyy
well at least you didn't ask about what an SR20 is :)
Cyberkreig
Car: 1993 Nissan 240SX SR
or how much $$$$ For a swap!
240_Keyy
Or what VTEC does :D
Honda Hick
240_Keyy wrote:Or what VTEC does :D
You mean V-TECH? hehe
I H8 UR DSM
I H8 UR DSM
Tai Mai Shu
lol classics
goldollar
Car: cars
where would i tap for oil pressure
yellow_jacket
Car: 95 240sx
The easiest way to do it is to remove the old sending unit and put the one you want in or sometimes there are other passages you can tap into. Right now they are currently plugged with a bolt.
Honda Hick
If you want to get fancy and retain your stock oil pressure sensor just so you still have a dummy light in the cluster you can T that hole coming out of the block. Use some nice stainless steel hoses and some Earl's fittings and make mount a T onto the firewall. Don't make 2 connections right off the block with adapters though because the weight of all that crap can cause it to snap off and you'll have 30-80psi of oil squirting out of your engine:dunce
