SuperSpeed »
https://forums.nicoclub.com/superspeed-u19529.html
Tue Sep 20, 2005 2:18 am
It definitly sounds like a timing issue, does it shake, or backfire? I did a head gasket on my 240 after a mishap with a thermostat, when I rebuilt it I didnt refference the Distributor when I put it back in The damn thing was 180 off which only put 1 of the cyl on the correct order, It would backfire and shake like all hell but wouldnt start, Dont assume anything. Double check every thing you did. Dont tell yourself Oh thats so simple I would have never done that or It right I dont have to check it, Timing Is easy, just start over, Set to TDC on #1, Re install the distributor, check the Coil plug is in, check the firing order on the cap to the plugs, if alls good, It should start, also check the fuel filter, if you can get it to start on ether and it runs, check the fuel supply, just cuz the injectors are getting the pulse, who says the are getting fuel. Im off my soap box, good luck
