Just checking up on my spring time tuneup... Here is what I have planned...
1. transmission cooler2. Brake fluid3. TCS fluid*4. AC Maintenance5. Radiator drain/clean/refill6. transmission pan drop and filter7. o2 sensors (maybe)8. Interior replacement (woohoo!)
Now for my individual questions regarding each
1. is there a transmission cooler I can get (cheaper) from like advance so I dont have to wait to get one IE the B/M 70268 (im not a nerd for knowning that part number off the top of my head)... One that will fit in the usual position (decided not to put it in the active cooler place).....
2. Whats the best way to do it.....?? Vague question, but I saw this at harbor freight (BTW if you dont know where one is FIND one, its like heaven!)
http://www.harborfreight.com/c...38053- My question regarding this is how do I actually go about bleeding... I have read threads on stuff like this, but im illeterate when it comes to bleeding... I know that your supposed to pump the brakes and then undo the valve, then repeat many times.. How will this tool help me (if at all)
3. Is it possible/worthwhile to change the TCS fluid.. I know its brake fluid, any easy way to do this??
4.
http://www.harborfreight.com/c...=3952 I was planning on using this vacuum pump and doing my AC vacuum/recharge myself (getting some R134a from walmart), would it be better to let the pros do this (I have a reasonable shop that will do this for me no problem)
5. Pretty self explanitory... However, I had planned on cleaning it myself by mixing up some CLR and letting it sit in there for a while..... Bad idea, as it might weaken the radiator (have heard of this happeneing to heater cores before).. Obviously I owuld drain it out really well first and not let any get in the engine, and flush it out before final fill... Would one of those radiator flush/cleaners be better than CLR?
6. I had a flush done about a year ago, or 7000 miles... hardly time for a flush, however I dont think the filter and pan were adressed (plus I wanna switch to M1 synthetic)... What I had planned on doing is the "poor mans flush" of a complete drain/refill. I hear that if you let the pan drain overnight that 95% of the fluid will come out.. Does the pan need to be off for that, or draining it via the drainhole sufficient.....?
