ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Thu Mar 15, 2007 7:14 am
Update: Just got done pulling the plenum (fun fun as always). I pulled up both fuel rails with injectors intact as I suspected it may be a leaky injector or some O-rings. Well, when the fuel pump primes when the key is turned on, there's no leaks. When I crank the motor, all injectors squirt out blasts of fuel. So I think those are fine. I have compression (160-170psi). I have fuel being injected, and I'm getting spark (timing reads right near 15* BTDC when cranking the motor). So with those things, I'd think it should fire up and run at least decently. I checked the throttle position sensor and it checked out good. The temp sensor was a bit low on the ohm reading, but that should only make it run lean if anything. I've taken out the #1 and #2 spark plugs and they look alright and they fire when cranking the engine and I've got them in the coil with the ground strap touching the motor. They don't look to be in bad shape but the plugs certainly aren't new. I'm about tempted to just throw some new plugs in there and see if it fixes it. I can't imagine it would though. The motor has started twice for me and it runs VERY rich, puts out a bunch of grey/black smoke from the exhaust, won't rev over 4000rpm, and then the exhaust becomes flames shooting out the back when all that fuel ignites. I've taken the hoses off the fuel pressure regulator and damper and there's no fuel smell or wetness from them. All vacuum hoses look to be fine also. This is really confusing. I don't have a clue what could make it run so poorly (usually won't even start, throttle open or closed). Is it possible that the plugs are firing on the wrong crankshaft rotation? I see no way that the CAS could have become 180* off on its own and the 3 bolts that hold the CAS on didn't appear to have been touched lately. Any ideas? Anyone, anyone? Bueller, Bueller?
