I woudlnt count on autozone having anything trustworty for the Q45 in that regard.. Hopefully its just a leaky hose, which they would have a makeshift replacement you could use until you can get one from Joe...CPQ wrote: If the parts come in tomorrow afternoon I'll get to the pump, and hopefully the leak is a small issue that Advance or Autozone will carry a part for.
If the new water pump comes with a paper gasket use that and sealant.Is the bolt(s) loose? If not, then I bet your money the weep hole is making it look like the bolt probably leaks. Once they wear to a certain point the seals leak out the weep hole.CherryPoppinQ45 wrote:
Just noticed in the FSM the water pump has a liquid gasket, is it unusual for these to fail?
Modified by CherryPoppinQ45 at 5:31 PM 12/24/2004
Thats a good idea. I couldnt get the darn thing around the groove in any way that actually fit. It was simply too big. I dont know if it expanded over the past year or what. I need to go in there again and seal the little cut in the o-ring with a dab of RTV.CherryPoppinQ45 wrote:I put the o-ring anroud the pump first and used a tie to hold it into place through one of the bolt holes.
The SHAFT seal is leaking. It can only be fixed by replacing the water pump.CherryPoppinQ45 wrote:I don't want to get a new water pump if I don't have to. I am asking if it were as simple as taking the existing water pump off and discovering the old gasket seal to be bad. What is the life span of the water pump?
Quote: "Once they wear to a certain point the seals leak out the weep hole" Once what wears? The weep holes or the gasket? If the weep holes are worn does that mean a new water pump.
I can see how the coolant level got low and gave me the funny temp reading and not the thermoswitch/thermostat. I found the leak and its definetely coming from the water pump area.
bigred211 is selling a wter pump on the parts thread for something like $10.00 or $15.00. Off a 90-93Q. I think I just bought his Knock sensors for $21.00.CherryPoppinQ45 wrote:I don't want to get a new water pump if I don't have to. I am asking if it were as simple as taking the existing water pump off and discovering the old gasket seal to be bad. What is the life span of the water pump?
Looks like a pretty good buy. If that's the pic of the actual part looks like a quality reman, and they do say it's factory. I would have someone watch the voltage as you drive around. See if it fluctuates. It should be above 13v at all times.CherryPoppinQ45 wrote:I have been in the archives and found a thread where valve cover gaskets leak on the alternator and destroy them. I know its not fuel now and I like your idea, but if its a 12 volt cig lighter won't you just get 12v and under? Or was that your point?
Will you check this alternator out and tell me if you would get it. He has a 1yr warranty. http://cgi.ebay.com/ebaymotors...%3AIT
I know I would take my chances but I would have a year.
I have seen a poor connection cause voltage spikes and dropouts. The car runs like ****.
Hey, I know what you mean!! It seems like everything goes at once or one little thing causes problems and you can't find out what "it" actaully is. LOL man!! Stick with it and your Q will love you back eventually. One thing about the Q is that it likes to snug with your wallet.CherryPoppinQ45 wrote:So in the meantime I'll call Joe and order the water pump, thermostat, and belts.THEN I WOULD HAVE REPLACED EVERYTHING AND THE F"ING PROBLEM SHOULD BE FIXED!!
