I dropped my transmission, and i am replacing both the front and rear oil seals.
The service manual calls for some multi-purpose grease to be applied to the inner lip of all the new seals.
Isn't some transmission oil enough? I was going to put some MT90 oil all over the new seals to press them in...
Otherwise, can i use some moly grease on them?
Also, would you apply sealant on the transmission cover plate gasket? Isn't a new gasket enough?
Any advice?
