philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Mon Jan 02, 2012 11:15 am
[quote="kerrton"...but some diehards add the fittings themselves so they can be greased. But your Rogue will not have any fittings from the factory...[/quote]
You can't add grease fittings to the Rogue, period.
Grease fittings are no longer found on most modern vehicles. Suspension design has advanced to the point that grease is no longer needed or required.
All that is required is periodic lube of the hinges (including hood and rear hatch), door locks and door stays. DO NOT lube the black and chrome looking struts that hold the hear hatch up! As for lube, I prefer white lithium grease in a spray can.
