Grease driveshaft
accurate
Car: 02 Nissan Pathfinder LE
So I was try to greasing the main & front driveshaft today, I can only found the nipple on front driveshaft but not the main :confused: ? Can you help me to locate the nipple on the main driveshaft? My is 02 LE.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
The grease fitting rotates with the driveshaft so you may need to move the vehicle a few feet to get it pointing at an angle where you can grease it. I've only had one instance where it was facing upwards and was ungreaseable in that position so far, I guess I'm lucky.
