Gray liquid coming from the oil.
holmeS13
Car: 1989 s13
Brought a project car with a blown head gasket (bad water pump). Replaced it all and I found that the oil is like gray color. I don't know if thats the color it turns when it over heats or what. I don't know what it is, I know all it all seperates (gas and oil) so was wondering if it might be a different problem other than just overheated oil.
sliders
Car: DRIFTING
did you change the oil after you replaced the head gasket ? if not that is from the coolant mixing with the oil and is normal from a blown head gasket , just change the oil and filter. If this happened after you changed oil and head gasket then you have coolant mixing with your oil and have to find out why.....
holmeS13
Car: 1989 s13
Thats alot for the help.
