szh »
https://forums.nicoclub.com/szh-u149.html
Tue Jul 29, 2003 1:57 pm
Thanks, Grant and Dennis!
I appreciate your comments! I'd like to ask some additional questions though, since I think I have taken some of your thoughts into account:
Dennis: Must find tires with load index of 95V or higher.
Absolutely agreed! All the tires I am considering are all 95V or higher load ratings. In a 245/45-17 size, the SZ50EP is my current first choice, but I am also looking at a few others - all are 95V or 95W. Like the Yokohama AVS db S2, Yokohama ES100, BFGoodrich g-Force T/A KDWS and Bridgestone RE750. Although they do have differing Max Inflation Pressures (MIP) - see my question below.
Dennis: 255/50-17 needs at least an 8" wide rim.
I thought so too ... initially. But, at the Tire Rack web site, almost all the 245/45-17 tires show a width range of 7.5"-9", whereas the 255/50-17 specify a range of 7"-9" (i.e., a smaller lower width - see the info on Bridgestone RE750 as an example.) I attributed this to the taller aspect ratio that allowed a bit more curvature in the tire sidewall. Would you agree with this, or am I pushing it too far? The Bridgestone RE750 255/50-17 is a 101W rated tire, by the way, at a MIP of 51psi.
Grant: Check the brake clearance behind the wheel.
Yes, indeed! Before I decide to use these 17x7 rims, I was planning to put them on the car (without a tire) and see if it had any problems with the brakes and stuff. Since they do seem to have a lot more "room" inside the wheel compared to my existing 15x6.5, I am comfortable that this should be okay, but good to check, agreed!
Dennis and Grant: Tire width points on the curve are not the same for all similar size tires.
Good point. I was also looking at the stated section width's on the Tire Rack web site to see if I could figure it out. Unfortunately, there is not enough data to provide a clear answer.
Grant, on a related topic, I have always been confused by the Max Inflation Pressure description - the explanation at the Tire Rack web site and responses here have not been clear to me. It became a bit more confusing with your info that the SZ50EP "would be fine at 1437 @32psi".
So, what is the difference between a tire rated at 95W with Max Inflation Pressure of 44psi (like the Yokohama AVS db S2) and a tire rated at 95W with a MIP of 51psi (like the Yokohama ES100) or a tire rated at 95W with a MIP of 35psi (like the Continental ContiExtreme Contact) ... all at 245/45-17? If the tires are all used at the same actual pressure on the car, does this mean that the Continental has the highest load capacity at ... say ... 32psi?
In other words, what does "Max Inflation Pressure" really mean? How does it relate to the load rating?
Z
