You can calculate that yourself...
Look @ your current rims, look @ the offset (stock is +40). Take a tape measure and measure how much room you want to go out... then convert it to the proper width/offset - you could use a wheel offset calculator for that too.
something like this:
http://www.1010tires.com/WheelOffsetCalculator.asp
Also, you can search because there's billions of threads like this.
To somewhat help you, I run x9 +20 all around w/ 225/40 stretched tires w/ -2 camber all around and it's pretty much "flush" w/ roll only (slightly pulled simply bcs rolling fenders will pull it a bit).
so you could run something like x8 +7, x9 +20 or less w/ -2 camber and be "flush" - according to my tastes in flush.
Iono if gramlight 57pro comes in those offsets normally (prob need special order).
If you are gonna roll & flare, might as well get the lowest offsets they offer.
