gram light size / offset help on my s14
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
i am in the proicess of buying new rims for my car.... i was wondering what offset should i use on the gram light 57s 17x9.5 wheels on the rear of my car....+12, +22, or +38 ?
crzycav86
Car: 93 Nissan 240SX KAT
I'm thinking +22.
You might want to use the wheel offset calculator and go compare the new distances between the strut and fender. The calculator is in the wheel faq.
cyrus240sx
well with a the offset at +22 the calulator comes out with
The clearance from stut housing to the inside of the wheel will be 9mm LESSThe outside edge of the wheel will EXTEND an extra 55mm
kclo4
Car: 1995 S14 with kouki front end. Track slut.
I have 17x9.5 +38 gram lights 57C that were on the rear of my S14. With a 265 wide tire there was maybe half a cm of clearance between the tire and the fender(not rolled) with some negative camber. With more neutral camber it would rub the fender I think, but not positive.
I am not sure about clearance on the inside though. It wasnt hitting anything but I don't know how close it was.
The front have 17X8.5 +40 with what I think is a 5mm spacer and there is no clearance problems.
http://home.comcast.net/~paxton_l/240sx ... 240sx8.jpg
Those are some pics of my car with the Gram lights if that helps.
I am actually trying to sell these to pay for SPL coilovers since my GAB's seals are exploded.
gepeto
Car: 1995 S14
I am about to get 17x8.5 gram light 57s ..
Will +22 fit on my s14 ?I suck with wheels
chmercer
in the rear, DEFFINITLEY +12. unless you wanna run 0 camber and not roll your fenders. which sucks.
Exar-Kun
Car: 2005 350Z
why would you run more negative offset than is needed to fit the rim width? all its going to do is hurt your wheel rate, hub bearings and cause massive track-width differential issues (differenc ebetween f/r track) with the car....
-Chet
