reflashed ecu = rom tuned ecu = "modify the maps in your existing one" (ecu) [unless you have an extra ecu - search for "enthalphy"]
If you're going with a reflashed ecu, you're better off getting everything together first.
as far as the 2871r on stock s13 sr20det, you can drive with boost below .5 bar or below. I think this is pointless if you have a functioning turbo system, t25 or whatever it may be. The reason I did it is because I had an exhaust leak and thought I might as well upgrade. I was told it would run below 14 psi w/o any problems but that's what I get for listening to other people.
I think you should get a stand alone first w/ a wideband and tune as you go along. Just don't blow up until you get your final turbo/manifold/intake/etc.. of choice. I think I will be happy with what I have because this is my daily driver with AC and all. That's why I decided to go with the rom tuned ecu. Speed however is addicting so I think you'll upgrade to several turbos before you decide your next better fast stronger project, a stand alone might be better and you can take it to your next project
nwmrkt wrote: get that thing tuned asap!
I will but so far it is drivable, just not as fun.
good luck
