GPS / TV/CD/Problem
bhf
Car: 2001 pathfinder
Hi guys im new to this forum .i have a 2001 nissan pathfinder and today my overhead tv stop working so i try to play i littlebit with it .so i disconect the s video cable from the reciver and puged again but now my TV/GPS/CD/AC/none ofthem work do you guys know what can be the problem thanxsorry for my bad english
RuskiQX4
Car: 02 Infiniti QX4 2" AC lift /w 265/70-17" tires.
When you say it is not working what is your problem? Is it not getting any power? If so, then check whatever you have it connected to or fuse.
bhf
Well it was working but than at the same time all of them JUST DIED my CD PLAYER/TV/NAVIGATION SYSTEM /AC COLLING They just died
rickinfinity
Car: 1989 Nissan 300zx. 2001 Infinity QX4, 2003 Nissan Murano
Hi folks. Also new to the forum.I bought a 2001 QX4 last month and have a couple of questions.On the forward part of the center console, forward of the shifter, are 3 switches. the first two, from left to right, are for the heated seats. The third is labeled Aux and is a on/off switch, what does this control?Also, there is a video type screen in the headliner, meant to be viewed from the back seat, that pulls down for viewing. Is this a DV, VCR, or possibly a TV?In the trunk/hatch area on the left side viewed from the rear is a vertical box mounted next to the wheel tunnel. Is this the cd player?Any help you could give me I would really appreciate.So far, with a soft right pedal I am getting 17mpg in mixed driving and 22mpg when I take it to the flatlands using cruise.Thank you for your help.rick
