Me too.Graflo wrote:Saftey feature....
You can only see the first page while you are driving. You should be able to see the rest if the car is in park... I did the same thing with mine.
Ohhhh... nice toys... TYbschurr wrote:Me too.
Click here for a solution
While I like much of what you see in the link, for example the auto door locks, etc. you can roll your own for the nav depending on your desire for the bells and whistles or simply to be able to program it on the fly. The kit is great in that it adds things like auto punching your ok button when the car is turned on etc. If you simply want to program it keep in mind what prevents you from doing so, basically the speed signal. This also pertains to the hard drive as well. The aux input has a similar issue if you want to add a carputer into the display (such as the camp 2).Tsunami_Dan wrote:
TD
You may want to do a search for this as it is on many forums dealing with Nissan products. Basically you need to remove the speed signal. Some are simply toggle switches, others involve something like a push button with a 15-30 second 555 timer, etc. Just a matter of how many bells and whistles. All I have seen involve hacking into the harness at some points which is why at this point I haven't done this myself as I would like to see a patch cable that makes everythings simply a plug in.Tsunami_Dan wrote:Anyone familiar with another type of solution or competitor to KP?
The NAV system only fully functional while stopped is unaceptable and in fact when you have a passenger who is more than capable to push buttons while you drive... this feature is embarrising and a hinderance at best.
ANy more suggestions would greatly be appreciated.
TIATD
Perry - This looks like the solution we have both been looking for --> http://www.tvandnav2go.com/in-car-dvd.htmlpfarmer wrote:
Perry
To me once you get the aux part of the mod done then it allows other things to possibly occur. For example adding an equalizer to an after market system that has a video display. Adding a car computer into the mix through the aux ports is another. A radar detector on your screen. There are lots of possibilities that open up.bschurr wrote:Perry - This looks like the solution we have both been looking for --> http://www.tvandnav2go.com/in-car-dvd.html
I am gonna get in touch with them when I am back in the office Wednesday & see about pricing. I'll keep you posted!-Barry
I installed the NI35 earlier today in my 09 Vert. I can confirm that the wiring harness is exactly like the 07+ coupes. Installation was about an hour including the nerve racking soldering of 2 wires onto the circuit board of the "Enter" button.KPierson wrote:I haven't come across any other navigation product for the '07s-up. In '07 Infiniti went to a much more complicated system, and the old "555" timer solutions no longer work. The older cars worked on a basic (-) pulse, the new cars have a communication bus that makes reading the OEM buttons much more difficult.
The best part about the KPtech NI35 is the fact that you don't have to add any extra buttons or switches to your brand new car - every thing works through the OEM "Enter" button.
We, at one point, looked in to making a patch harness, but because we would need to make two seperate harness to make it plug and play, and both harnesses are expensive and have fairly high pin counts, it simply isn't cost effective for us to commit to making them. The NI35 has current limited inputs/outputs which makes it extremely difficult to damage anything in the car, even if it is hooked up incorrectly!
