all4sho wrote:yeah that wiring looks real good jumped in the fuse box... and the aux wire hanging across the dash Real Trick i see you got you money's worth
The wire across the dash that you saw in that other picture is only there if she wants to run the sound through the car stereo. There really isn't a need to do that since the unit is so close to the driver where I mounted it. You can hear it just fine. Most of the time it looks like this:
As for the connection in the fuse box, it's a clean connection that can only be seen if you open the fuse box and look at it. But if that bothers you, by all means, spend $100.
