jerryc41 »
https://forums.nicoclub.com/jerryc41-u150070.html
Fri Jan 22, 2010 5:06 am
Got it. I drilled progressively larger holes between the defroster vents. It would have been easier with a right angle drill attachment. The hole (3/8") looks worse in the flash pic than it does in real life, but it won't show Long - very long - nose pliers pulled the wire right through.
Rather than use the adhesive on the metal GPS plate, I'll use one of those black rubber sticky pads to hold the plate. With the wire going through the dash, the antenna won't be going anywhere. I'll cut a groove in the plate to let the wire pass through.
I hope to get this install basically done today because we have to go somewhere with the Cube tomorrow, and my wife knows nothing about this new system. All she knows is that I'm "doing something," and she can't use the car.
Jerry
Modified by jerryc41 at 9:00 AM 1/22/2010
