Yes, it does still do that to some degree, but the percentage above a certain point asymptotically levels out.C-Kwik wrote:How does your theoretical proposal compare to current taxes? Since ultimately, it works out to a graduated tax anyways.
Most importantly, it corrects one major inequity: that the percentage rate increases with income!
Yes, it is at 38% now, but in the not too distant past, it was a lot higher ... and we could see a return to those days if some of our Socialist Congresspeople have their way! That is manifestly wrong, and should be called "theft" - the government dipping into your pocket call it "tax" to make it nice and clean! Let's walk the walk and get away from that absurd position to find ourselves in.
1. Studies show that a flat percentage tax system will be relatively revenue neutral, and may even generate a bit of extra money for the government from individual. So, no extra taxes are needed.C-Kwik wrote:Further, and more importantly, what is the difference in tax revenue generated? If less money becomes generated then how do we make up the difference?
2. For higher income ranges, most would actually be paying a bit more in actual total percentages, as it turns out. Because, all deductions would be eliminated (with only the theoretical "poverty" level in place).
3. The burden on most people below $50,000 total income (assuming a $30,000 poverty deduction) would actually go down a bit, and for people below $30,000, there would be no "tax" at all.
4. The burden of calculations and maintaining an ever-increasing tax code could be reduced/eliminated - we waste too much time and money on taxation calculations.
Now, having said that, I realize that all "plans change after contact with the enemy". So, it would need re-evaluation later and the two controls/variables ("poverty level" and the "percentage rate") could be adjusted to correct for perceived revenue problems.
Of course!C-Kwik wrote:Ultimately, no matter the tax plan, we need to try and ensure a certain level of tax revenue.
But, personal income taxes are not the only source ... not even the single largest source of revenue for the Federal government.
Understood and I do agree. Which is why a "pure" flat tax, without some support for the low-income folks who would be crippled by it, will never fly. Hence my proposal for a "poverty level" definition - termed so that people would find some pride in rising above it (I hope anyway).C-Kwik wrote:In order to do that with a pure flat tax, it would be so high that low earners would be crippled by it (Close to $7K per taxpayer by my estimates).
Another way to solve that problem would be to declare that there would be no "poverty level" at all, and that the amount would be a flat 20% tax. To help the low-income people (below a threshold - adjusted for inflation), there would be financial money help equal to the amount of tax paid - this would not be termed a "refund" (I hate that word!), but would be termed a "credit" perhaps, or "assistance", or some other word where the connotation of inappropriate entitlement would be removed.
Sure!C-Kwik wrote:The plan you use is still biased against the higher earners.
But less so than the current inequity ... which is likely to soon get worse if some Congresspeople have their way! The marginal tax rate may increased at the top end to even more than it is now because "rich people can afford it more" BS is applied.
I have shown the actual figures in another thread in this forum. The numbers for personal income tax is not that big a chunk of the total tax revenue ... corporate taxes account for a lot more than you would think!C-Kwik wrote:And chances are, the actual tax rate would need to be higher than 20% to provide as much tax revenue as we get now (A little over 1 trillion in 2006).
1. Really well done studies - without an axe to grind against the "rich" - show otherwise!C-Kwik wrote:The reason for this is that the 30,000 deduction would negate almost 26 billion in revenue from people making $30K and under. Not to mention it would also lower the Taxable income across the board by $30K per taxpayer. Once you get over the $500K adjusted gross income mark, those taxpayers are already paying more than 20% of their AGI in taxes.
2. And, the numbers can be adjusted accordingly to tweak things. So, change that 20% and make it larger if needed to make it revenue neutral.
BTW, I say this knowing that it could impact me adversely too - I make enough to be hit by it, rather than pay less.
The problem is that the "rich" do pay 6 to 20 times more. So, still unjustified, IMHO.C-Kwik wrote:I might argue they do get better benefits. Perhaps not on the order of 6 times more, but more affluent areas do indeed to tend to have better teachers, facilities and public services.
Z
