Ironically, they're both black 94 Qs, maybe they're cursed somehow...
Anywho, heres the symptoms... We suspected the MAF, and swapped in a known good MAF...
Basically the car feels like its running on 4 cylinders, but the cars idle smoothly and under no load revv just fine..... On Jason's Q the power balance test was perfect, they were all within like 5 RPM or so..... Interestingly enough, with Jason's Q it feels like when you just touch the throttle it feels fine, but when you give it gas it just bogs down, kinda like when the accelerator pump is bad on a carbeurated engine......
On both cars the knock sensors turned out to be bad, and on Jason's Q the o2 sensors are barely hanging in for dear life..
NO CEL's either...
The only other common denominators are is Andre's Q has bosch plugs, and I dont know about Jason's Q but Im going to replace the plugs anyway.....
I can safely say I dont think the KS and O2 sensors are causing the problems.. BOTH of them said when they were describing the problem they both said it feels electronic "like something isnt set right".. And I agree.. In Andre's Q we put in my ECU just for kicks and giggles, and no difference.....
This has me totally lost....
