WHE90Q45 »
https://forums.nicoclub.com/whe90q45-u85657.html
Wed Jan 23, 2008 5:21 pm
well i'm not sure how complete they are.... but here's the lowdown....
here's the VIN :JNKNGO1C4LM003506
12/06 - intake manifold cleaned, leaky fuel hoses replaced, "also had to drill broken intake bolts"(?)6/06 - replaced fuel injectors #5, #8, intake manifold gaskets. replaced a/c compressor, evap, filter, recharge.6/98 - fuel pump and fuel pump module r&r. drivers side sun visor r&r (71,xxx miles)10/00 - all 4 struts replaced (OE) (doesn't look like any bushings were done, unless the OE struts came with a bushing kit)12/93 - looks like body work on the drivers door and a rocker panel2/96 - new brake master cylinder8/00 - glove box replaced (at the dealer!! $385.14 for real!!)5/99 - brake light housing repaired8/98 - power steering hose clamps replaced11/01 - rear inner tie rods + outer bearings + rack boot12/01 - rt. valve cover, #6 lifter, rocker arm, valve cover gaskets 1/02 - fuel leak at pressure hose to pressure regulator12/01 - fuel leak at front rail clamps6/04 - a/c converted to r134a7/04 - a/c condensor replaced12/04 - left rear cat convertor ($400.00 for the convertor?!!?!?) trans fluid flushed (but no mention if filter was replaced? but "conditioner" installed)1/05 - left rear brake caliper6/05 - a/c compressor, reciever, dryer, switches. ($1,058.00!!)8/04 - brakes and rotors (pads used were bendix metallic)11/02 - body work front drivers fender r&r, front bumper r&r. etc.
OKOKOKOKOKOK so obviously what can we tell? THE CHAIN GUIDES HAVEN'T BEEN CHANGED. so where is the car? in the shop. getting new brakes (i'm getting a price tomorrow on a few different options, from OEM on down to wagner) and fresh oil (mobil 1, yo) and a price on the chain guides.
and it's getting a transmission flush/filter change. cause the dreaded cold 2-3 delay has creeped up... and i'm hoping a fluid change will help it. probly gonna go with full synth transmission fluid.
yes i am getting the chain guides done very soon as well... but i need to find a shop that doesn't go "uh you need to take the engine apart to check the guides" when i ask them to check the guides.
so does anyone know any NE ohio shops that know about this stuff? i know there's a 300zx TT guy who runs north shore racing, but i haven't heard back from him.
anyway i'm hoping if i take care of these issues (brakes, transmission, chain guides) the car should be solid for, oh, 6 months? please advise......-chris
Modified by WHE90Q45 at 7:56 PM 1/23/2008
