Got these tools laying around??
TurboLS
Car: 1994 Integra LS Race Car
2000 Integra Type-R Daily Driver
So, as AutomotiveSpecialtyTool.net progresses along, we'd like to get a running tally of all of the tools in which people are interested for borrowing/lending purposes.
We plan on incorporating something similar on our site to help users prioritize which tools to post up, etc...
We encourage those who have any combination of these to post them up, at no charge, on AutomotiveSpecialtyTool.net
We will be checking this thread periodically for updates, etc.
If the tool is make or model specific, please indicate that as well as part numbers/manufacturers whenever possible.
Thanks for any and all input.
- Ramzi
- stubby, ratcheting 21mm wrench
- RTAB bushing pullers and press -> BMW
- Differential carrier bushing pullers and press -> BMW
- Differential bushing puller and press -> BMW
- Fender roller
- Wideband O2 sensor
- Sir Tools B90 or similar wheel bearing puller
- Piston ring filer
- Shallow swivel E-torx sockets...money when trying to remove your bell housing bolts on BMWs.
- E-torx sockets (E10 to E16)
- 6 speed clutch alignment tool (22 spline???)
- Master tool set to remove all of the busings/mounts in an E46
- Removal/Install tools for the Meyle HD control arm ball joints
- Stubby T60 socket, 1/2" drive
- BMW M3 S54 Valve Adjustment Kit
- BMW 5346 Power steering fitting removal tool
- TOL-BMW3055 BMW VANOS Cam Timing Master Kit which includes:
- TOL-BMW3041 aka 11-3-450: VANOS Air Compressor Adaptor
- TOL-BMW3042 aka 11-6-180: VANOS Cam Sprocket Jig
- TOL-BMW3043 aka 11-6-150: VANOS Camshaft Alignment Jig
- TOL-BMW3046 aka 11-4-220: VANOS Rigid Chain Tensioner
- TOL-BMW3047 : VANOS Chain Tensioner Lock Pin
- TOL-LIS28100 : Lisle Torque Angle Meter
- TOL-3017 aka 11-3-240: Camshaft Holding Tool
- 83-30-0-490-856-BOE: Torx Socket for BMW Head Bolts
TurboLS
Those of you that have played around with the site a bit: what do you think? easy to use? needs to be more intuitive? what can we do to make your lives easier as DIYers? Let us know when you have a minute. Thanks!
TurboLS
Piston ring filer added to the wanted list.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
TurboLS wrote:- OEM or OEM-fit, working catalytic converters that pass emissions
isn't that illegal?
Dattebayo
isn't that illegal?
Yep. Illegal unless they're unused.
themadscientist
Are you supposed to keep those things? Whoops.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I would think a transmission jack would be a good tool to rent, however that might not be cost effective to ship!
What about like painting supplies, like an orbital sander or even some spray guns?
I would think that a nice selection of grinders or other cutting/metal working things would be good to have.
TurboLS
Sounds good. Body work tools are definitely sought after...
audtatious
So, are you simply posting here as a means to get people to see your site and possibly rent/buy tools?
Dattebayo
audtatious wrote:So, are you simply posting here as a means to get people to see your site and possibly rent/buy tools?
He has an agreement with Greg.
TurboLS
Essentially, you've got the idea. Since our launch in November, we have been trying to promote the site to owners of these high dollar, specialized tools so that we can build the P2P database of tools. Only then will it really be useful to borrowers.
We are also trying to add features as quickly as we can afford to do so to make it as user friendly as possible. We do realize that having to send multiple payments via Paypal in addition to the one processed through the site to conduct a transaction is a bit cumbersome. However, this is why we are trying to gauge feedback so we can focus our efforts on those issues which people find most important.
Dittoz7
Car: 1997 2f0WtY SE!
themadscientist wrote:Are you supposed to keep those things? Whoops.
x2
TurboLS
List updated with requests from all affiliated forums...
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I love the smell of unburned hydrocarbons in the morning!
TurboLS
More BMW tools added to the "Wanted List"... We've also made some improvements to the user friendliness of the site. Feel free to take a look when you have some time.
- Ramzi
TurboLS
So we've made some updates to the site. I obviously went off the grid for a while and am just now getting back into the swing of things doing some stuff online. We now have just over 100 users registered on the site and more tools than before. We are still trying to get those owners of the high dollar/sought after tools to post more of them up to continue building the database. As always, any and all suggestions are appreciated. Thanks!
TurboLS
Does anyone have an R12 refrigerant extraction kit (or whatever the technical term is)?
costa_rican13
Car: 1993 s13 coupe
me too! :) gotta love it!
Encryptshun
Car: 2005 Nissan Xterra
TurboLS wrote:Does anyone have an R12 refrigerant extraction kit (or whatever the technical term is)?
You need an EPA license to possess a freon evacuator, as well as submit to regular inspections of the equipment in order to keep your license. Full cylinders of reclaimed freon must be sent with appropriate paperwork to an EPA authorized reclamation processor who will send you back an empty cylinder.
I would not post anything about EPA-controlled equipment on a public site unless you want to open the door for some scrutiny....
