Got the RB25 dyno'd and got low rwhp #'s
darkstar575
Car: s13 hatch
Congrats. What setup are you running? Your timing should be at 20?...Thats what it should be on my rb20det...
Tripz
Car: S13 RB25DET
Thanks, yeah I heard it should be around there too. Guess I double check my timing and retard it on the PFC.
Mods are:
S1 RB25DETgt35r with topmount manifoldtial 44mm wastegate3" dp and exhaustPFC w/ commandernismo fprgreddy intake manifoldavc-r boost controllerPOD filterz32 maf660cc injectorsand other misc stuff.
The numbers I got was very suprising and to be honest, I wasnt expecting that much from 13 psi on a mustang dyno. Should be a very fun to drive now and full boost kicks in at 3900 rpm
noodl35
I believe mustang dynos show 10-15% less than dynojets. So you really pushing around 248ish. Still a bit low from what you stated. But not as bad as 216.
Tripz
Car: S13 RB25DET
noodl35 wrote:I believe mustang dynos show 10-15% less than dynojets. So you really pushing around 248ish. Still a bit low from what you stated. But not as bad as 216.
Yeah it wasnt too bad when I first dyno'd it. But now it's way more than expected.
370rwhp is on a mustang dyno. So on a dyno jet with a difference of 14%, it'll be around 422 rwhp on dynojet.
Modified by Tripz at 8:26 AM 8/31/2007
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
I want to see the dyno with the GT35R.
Tripz
Car: S13 RB25DET
... meaning you want to see the dyno sheet?
DrifterProdigy85
yes please.
Tripz
Car: S13 RB25DET
There you go.
DrifterProdigy85
Did you have some boost creep issues?
Tripz
Car: S13 RB25DET
Yeah I did. All this was done with the boost controller turned off and was just using the wastegate's spring (1 bar).
