Lobot wrote:Your better off just taking out the factory airbox and using a K&N cone air filter rather than buying a whole intake unless you want the chromed out look. The piping is the same size.
NOT TRUE... and my AEM doesn't have an ounce of chrome on it! You can hold the AEM tube, and the stock tube side by side and there are three MAJOR differences. The AEM (and most other after-market tubes) are far superior to stock because:
1. the pipe is round (no narrow passages like the stock one)
2. the pipe has a larger overall diameter
3. it is a more straight, direct route to the tb.
Also... the AEM pipe is powder/zinchronium coated for heat insulation. It may not get you MUCH more HP than the K&N drop in filter.... but if you start adding header, exhaust, cams, etc... it will net a bigger gain for sure.
