got the motor in this weekend
Oneor1
Car: cars, music, hockey
Whats up guys?
Well I just got home from working on my CA the whole weekend at my bro's house. We got the KA pulled by saturday night.... bro was drinkin and wasnt too quick on his duties. Anyways we got the CA all ready and prepared and dropped it in today got everything bolted except the drive shaft kinda being a little ***** but we'll get it. now for my list of some questions......
1. What does that little sensor looking thing do that is located a little up and to the left of the oil filter? I have a connector with about a 3" wire comming out of it that is cut? Is this imperative??
2. will the wires under the dash be able to connect to the connector on the CA harness?
3. I thought that you would run a tiny vacuum line from the actuator to the turbo which would make the vacuum line maybe like 2" or so. But then I noticed that there is a hard vacuum line that is run along side of the head and ends right at the tip of the turbo...... any idea what i should do on that.... let me know if ya can
well thats my first round of ?'s
take it easy guys
-Rick
boost_boy
Quote »1. What does that little sensor looking thing do that is located a little up and to the left of the oil filter? I have a connector with about a 3" wire comming out of it that is cut? Is this imperative??[/quote] Ooooohhhh, you may want to hook that puppy up, bro because it's your knock sensor and it is very imperative or you will be getting a code 34 quickly.Quote »will the wires under the dash be able to connect to the connector on the CA harness?[/quote] With minor adjustments, but I'll let the others confirm this.Quote »3. I thought that you would run a tiny vacuum line from the actuator to the turbo which would make the vacuum line maybe like 2" or so. But then I noticed that there is a hard vacuum line that is run along side of the head and ends right at the tip of the turbo...... any idea what i should do on that.... let me know if ya can[/quote] Rick, connect the hose from the turbo to that of the wastegate actuator for now. This will give you stock boost (5-8psi) until you get a good boost controller. Hope this helps.
Dee
Nismo1182
Car: Z06
Oneor1 wrote:2. will the wires under the dash be able to connect to the connector on the CA harness?
On my 90, i matched up the wires color for color. There were like 5 or 6 wires left over, but its ok. The wires by the battery tray wire up the same as an SR. Its all simple stuff.
