got spark and fuel but no start!
my240sexy
Car: nissa 240sx
hey guys i need some help. im pretty much almost done with my sr20det swap but i cant get it to start. im getting spark and fuel for sure. i redid the ignition timing like 5 times, line up that needle thing with the second dot from the left on the crank pulley and installed the CAS at TDC. i had my friend try starting the engine while i rotation the CAS but nothing happen. any suggestions?! im so desperate for help right now, thanks
my240sexy
Car: nissa 240sx
oh ya im also getting a nice blue spark so i know im not just getting a weak spark.
mexicanracer03
Car: 95 S15FRONTEND SR20DET and 97 2JZ GT4294/ 93 SC300 Black/ 95 SC300 Green
so umm your fuel pump is kicking on ??
pete_07
Car: 94 s13
yeah check you're fuel pump
my240sexy
Car: nissa 240sx
ya im pretty sure its kicking on, i pulled my injectors and started it while they were out and i saw fuel sparying out of them. any other suggestions????
mexicanracer03
Timming but check the spark again. unless you know for sure your good on the at.
my240sexy
Car: nissa 240sx
i checked for spark, i took the spark plug out, stuck it in the ignition coil and grounded it to the valve cover. my friend cranked it and i was saw a blue spark. i do have a feeling it is my timing to since thats really the only thing left, but i also think im doing the timing correctly just like how this shows: http://www.frsport.com/How-To-....html
swartztech
Car: 1995 Nissan 240sx w/ S14 SR20DET
Im having the same exact problem man...just did my swap, i have fuel, spark, compression but no start...ill let you know when i figure it out
my240sexy
Car: nissa 240sx
ya , thanks man let me know
my240sexy
Car: nissa 240sx
hey guysss i freakin reversed the fuel lines! that was my problem the whoole timm woooow
mexicanracer03
hahah that was something simple. well that's good. at least it's not your Timming b/c that's alot of work to set.
