Which car are you putting them in? If you're putting them in one with a dizzy, pull all the plugs out, then put some of the regular plugs in the wires and some of the Pulstar's in the wires and set them on a good ground (manifold, valve cover(s), etc.), set engine to TDC, mark rotor location in the dist. cap, pull the distributor out, have the ignition in the on position (I'd pull the fuel pump fuse first as the injectors will fire), and finally give the distributor a spin. This will fire the spark plugs and will instantly show if you can see a difference. You may not want to mess with all that but would definitely be an easy way to see a visual first hand difference.NSR_s30 wrote:Got mine too woot! I think Thursday weather permitting maybe I'll get mine in.
zerothread/309763
They're going in his sentra....its coil on plug like the Z's.mtcookson wrote:Which car are you putting them in? If you're putting them in one with a dizzy, pull all the plugs out, then put some of the regular plugs in the wires and some of the Pulstar's in the wires and set them on a good ground (manifold, valve cover(s), etc.), set engine to TDC, mark rotor location in the dist. cap, pull the distributor out, have the ignition in the on position (I'd pull the fuel pump fuse first as the injectors will fire), and finally give the distributor a spin. This will fire the spark plugs and will instantly show if you can see a difference. You may not want to mess with all that but would definitely be an easy way to see a visual first hand difference.
Ran them for a week at a variety of plug gaps. I've had the NGK's back in the car ever since.JDMZ32 wrote:anyone have any results? i've heard NGKs > pulse. prove me wrong?
Answer enough?
