Got some Questions About The Rb20 in the R32
gonshik007
Car: Z32, S13 RB20det
There is a sensor that I don't see being plugged in it is located by the intake manifold in the front, on the side of the engine close to the valve cover!
The car has AEM Engine management system and the battery has been moved to the back!
Not my car but just something I saw that I wanted to know what sensor that is!
Thank You for your Help!
EVILS14
Car: 1995 NISSAN 240SX SE RB25DET
pics?
gonshik007
The Sensor circled with arrow!
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
That's for the Variable cam timing.
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
Yellow4g63 wrote:
That's for the Variable cam timing, +++1.
Do you need it pluged in= NO, I have heard it doesnt make much difference with it plugged in or VCT working.
Defiantly not a RB20 but a RB25,
Rb20's dont have VCT, and no Greddy IM for RB20 only RB25/26. And you have both so it would be a RB25, sorry no RB20
Only thing I see from the rb20 is the coil-pack cover, even valve covers are rb25
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
It is the variable valve timing solenoid.It uses a removable wire clip to stay connected so if you don't put the wire clip back on it just slides right off. It just bumps the intake cam forward when the rpm's go up.RB25's are the only RB models that have this solenoid nor any part of the VVT.
gonshik007
Thank you very much guys I am trying to learn all i can right now!
I understand what that solenoid does now! Thanks!
