Well after playing with the engine, reading how to's and what not's I had gotten it to run pretty damn good, with 155ish PSI on all 4 cylinders, going from conventional oil to synthetic with a can of restore I beat it to 240,xxx miles after 2 winters of snow drifting, in result this happens.
After hours upon hours of gravel roads, and what time I got to spend playing in the rain. Thought it was time to invest some money in to my daily driver(bad decision but I bet ill be happy when I am done).
So I decided I wanted to go ahead and rebuild an engine and put a turbo kit on it. Well as luck has it a kid has just picked up a boosted automatic 240 and bombed the transmission, and got the engine out of it the minute he sent it to the junkyard.($120)! lucky for me one of my friends knew the guy who built the engine for the car.(At a shop) But he deployed and I have had no contact with the guy and he has yet to return home. So after my car catching fire about 3 months ago due to a short or something(It was raining) I decided to take the weekend and replace my engine (which was still running like a champ) to put the new(er) one in and buy myself a turbo kit.
Well I went ahead and figured I would swap the engine, run it for a while N/A while I will buy turbo parts for it. I've read for almost 2 years about turbo KA's and have never even liked the idea of an SR. So having a single cam just made it that much more enjoyable.
I was pretty sure I got everything running right, maybe besides the fact I left emissions on for got knows what reasons, so I might be having an EGR issue, I just plugged the hole instead of getting a block off plate. I also never did get rid of the IVAC? Idle issue where sometimes coming to a stop it would give me that honda surge where it goes up to 1800rpms and down, up and down again. So at that point I figured I could live with that and went on a shopping spree.
I like this, $50 for a piece of plastic though? Better then pillar.
Anyways, after reading on turbo options I finally gave in to the CXRacing turbo kit, figured it would get me where I wanted to be, and I can replace the wastegate/bov/turbo later. I have read good reviews about this kit lasting for a pretty long time, wish I could experience this.
Now after getting everything on, I figured I would be sitting in a good spot. I was wrong, oh so very wrong. First thing I noticed was my AFR's were WAK; this could also be due to the retard who welded the bung to where my o2 sensor is wedged up against my valve cover breaking the wire. So after fixing the wire(kinda) I drove around (getting high 11's low 12's on AFR) Didn't care to much just eating a LOT of gas. Wanted to break in the turbo in time for an event here in the midwest called AMERICRUISE! Which I did not get to break the car in on time by. I went a head and took it to the event, and wanted to do a small burn out, well found out stock OEM clutches don't hold up to almost any boost at all. So later that night on the way home I smell smoke, and my exhaust got really loud. Oh well look at this.
Waste gate had came off, the bolts were no where to be found. So I took some lock tight to them, everything had ran fine for a whole tank of gas, but my AFR's were still funky and oh BTW I have not ONCE taken the car over 50% throttle. I wanted to see what I could do to change it so I got a 12.1 FMU, SAFC II. (Mind you I installed the 255LPH with stock injectors and no other tuning other then the SAFC II which I don't think is doing anything due to the broken exhaust o2) And it still didn't change anything. A change of events occur again the other day. I was out cruising and after rolling around and having someone snag this picture.
I can give the car about 45% throttle before the clutch just spins relentlessly and my afr's approach over 12.3. (9lbs waste gate spring with no boost controller) And next thing you know I smell smoke while doing a pull, and SOB...
Turns out this happened;
My problems come down to this; excluding the clutch.
Should I take the time to remove the emissions? Should I just get a EGR block off plate?
Getting the FC turbo 550cc hi imp injectors + an ECU rid of my AFR problems?
Also I am STILL on the table about ECU/a tune.
AND WHAT ABOUT COOLING?! I'm obviously having issues with keeping temps down, im also cracking spark plug wires from the heat, and found one arcing against the turbo before the mani blowing up. What all should I buy/get to prevent issues?
What about ignition timing? I retarded it about 10 degrees after replacing the plugs with NGK TR6's. Thought maybe that would help also with some of the problems. Another thing it was an auto car, that was manual switched, but when my harness shorted and caught fire I put a new harness and used an auto, and not a mani. From what I read its ok. Another thing I read up on was the TPS (black box that can control throttle plate right?) is different from automatic to manual cars. I don't know how to tell the difference all I know is I turned it all the way back to maybe help solve some problems.
I am in the dark on the compression ratio, but I know the whole rotating assembly is forged besides the crank, and it DOES have a cam, and the guy built it FOR boost. So I don't know what I would tell the guys at Enthalpy; Or should I get NISTune? I'm so on the table with ecu/tuning its making my head hurt and it sucks not having a DD, And I sure hell dont want to DD my other car. (Which is the green car in one of the above pictures).
I am completely out of motivation, and just completely lost with what to do.
Also had to ghetto rig the intake; since it has been raining and I have no fender well splash gaurds, it was a wet vac, so now it looks jank like so: http://a6.sphotos.ak.fbcdn.net/hphotos- ... 3374_n.jpg
This is how she looks now btw, Tien lowering springs(stock blown shocks), godspeed suspension. Tenzo DC-6 v1's 235's/265's 18x8/18x9.5
