MandTPhotography »
https://forums.nicoclub.com/mandtphotography-u101276.html
Mon Feb 16, 2009 5:19 am
Yeah I'm coming from 250 right now, and all I'm looking for is 300ish.
I just wanted to see how easy it was to do that with my setup, and apparently it's pretty easy.
I figure coming from where I'm at right now. (T25 on 14lbs, Stock Injectors, 247HP)
And going to.(PE1420 on 13lbs(?), 550cc Injectors, 30XHP)
I'll notice a big difference, haha.
Plus open wastegate will keep me busy for a while.
Main reason I want to do the swap to the new stuff is to reduce the strain on my motor right now, at least with the new stuff injector duty cycle won't be at a billion % and the turbo will still be in efficiency range with room to go.
