Got Some Goodies for you Z32 Lovers.
94Q45Beast
Car: 1994 INFINITI Q45t w/HICAS
1992 INFINITI Q45
2017 INFINITI Q70S AWD BLACK ON BLACK
Hi, my Company has made arrangements with various factories to produce High Quality OEM exceeding parts for Nissan / Infiniti cars, 2 of the many goodies I have to sell are Suspension and Brake Kits, I need testers for both, there are only 15 spots available to get these at a special Discounted "Tester's price", the names you see on the parts are a place holder for my company's name just so I can see what they look like.
Shocks to choose from:
LS : - Applied general shape springs: has a good effect on car height adjusting by vertical coil spring.
- Individual piston: individual piston can completely separate oil and gas thus keeping the damping force.
-Double tube structure: high speed series shock absorbents all possess single tube structure for higher radiation and inhibit oil viscosity changing, and minimize damping character changing.
RS2: - High strength spring: has Japanese high quality and strength material, “SAE9254,” the diameter has been minimized, but the dense coil can still keep the appropriate stroke and yield a lightweight and comfortable riding feeling.
RS3: - In accordance with the individual stages can stretch adjustable damping technology.
- Adjust the height according to personal needs
- Construction elements giving a high value long life.
- The complete archives give a simple application.
- Unique, and each operates independently adjust the damping force.
N1: - 24 position strain/compression damping force adjustable mechanism helps to give consideration to hard driving and
comfortableness, as well as superior performance. Meticulously designed damping valve van precisely control the
feedback force and handle all kinds of road situations.
- The dust cover made by a special resin material, it can fully protect from the shock absorber rod
against dirt, dust, rain and extend the shock absorbent's life and durability.
- N1 style applies newly designed spring fixing base, and has set on the best position when leaving the manufacturer. Please
check if the spring has been loosened after resetting the spring position.
- Inbuilt in tube valve: unfavorable vibration is mainly caused by the feedback of gas pressure. Though under high speed, the
tube valve and high damping setting can cause a lower gas pressure ratio, ensuring a comfortable ride and minimized
vibration.
- Large piston diameter: single tube structure helps to enlarge the piston diameter to 45f A arm (40f), and the larger pressure
responding surface can increase the valve’s initial response.
N1-R: The top technology for the sports style drivers. This mutual separation and can be independent adjust of the uphold side and compression side damping can be designed in accordance with all types of vehicles dedicated to its damping setting. This unique system achieves the traveling at low speed range set in the compression side damping during the three control loops, while in the comfort of high speed range is fully multi-adjustment feature. It can absolutely satisfy your most extreme requirements.
Suspension comes with a 1 year warranty
BRAKES
You have options of Rotor Thickness, drilled, Slotted, Wavy, or all 3, and plain, it is a 2 piece rotor, 6 piston calipers. Kit includes full assembly including brackets.
Colors to choose from:
94Q45Beast
1992 INFINITI Q45
Oh and I got more goodies for the Z32, the website is currently being developed from scratch (by me) and will take time, all the HTML, java, css, php, xml coding can get pretty hectic, but for now I'm looking for testers to test the product.
diederikdemot
Car: nissan z32 300zx tt swb
i'm intrested . i'm from europe
greetings
94Q45Beast
1992 INFINITI Q45
go ahead and pm me, but you need 10 posts to pm...your at 7...
94Q45Beast
1992 INFINITI Q45
Oh what the hell....I'll sell Carbon Fiber Hoods and Trunk lids + spoiler here on nico too until I'm done with the site as well as racing clutches and Kevlar and carbon fiber braided front strut tower brace and thicker sway bars and and full upgrades for all suspension components (control arms, tension rods...etc.) currently designing an electronic rear spoiler that raises up at higher speeds as well as carbon fiber rims. will post pics
rgregoryb
Car: 1992 300ZX 2+2 NA
also interested just not enough posts for pm, just over here in Birmingham.
OK'd by Mgmt.
94Q45Beast
1992 INFINITI Q45
thank you
NolimitZ32
Specs on the brakes? I would be VERY interested for the right price.
rgregoryb
Interested in the RS2 or LS coil overs, what is the price and how do we do the deal
rgregoryb @gmail.com
94Q45Beast
1992 INFINITI Q45
I'm out of the office till the 26th, will get back with answers to all questions
