As a matter of fact, the resistor wiring is one of the pictures i forgot to upload off of my camera for just this sort of question. However, this thread should help. You simply solder the resistors inline with the wires for to the injectors on this diagram (#'s 101, 103, 110 and 112 if you have an s13 sr): zerothread?id=218689Solow240sx wrote:Im also going to be running msd injectors with the resistors Would u be able to tell me how to wire the injectors and which wire the resistor should go in??
Yeah, just make each wire on the stock connector go to the corresponding wire on the MSD connector. You'll see what I mean when you get in there. It's really strait forward.Solow240sx wrote:Sounds good, does it matter which wire on the msd plug go to which wire from the ecu??
The S15 Helicals are very strong diffs and by design will "theoretically" never wear out or break, although it can happen. To be honest, I'd spend the money and take the diff to a shop to have it shimmed and back-lashed properly. That's just me, I don't like doing things half-assed, and I wouldn't want to be stuck on the side of the road or at the track because of something stupid you could've avoided.freakyjason wrote:Question about the s15 HLSD. I've heard that you can just drop it in without shimming it at all and it will work fine with acceptable backlash and so on. Has anyone done this successfully or do they generally need to be shimmed?
I couldn't see if being more than $100. Any autoshop can do it, it doesn't necessarily have to be a transmission shop...freakyjason wrote:Yeah, I'm not much of a mad tyte drifter either. I'm really looking forward to some extra grip through those tight technical corners. Maybe the next time I go to the track, I'll put a bit more distance between me and that evo (pictured above). What do you think would be a reasonable price to have a transmition shop do the shimming/checking the backlash?
